UserForm1.Show gives an error...
Okay, here's the setup: I've got an .XLS file storing a set of macros (modules) and a single userform (called UserForm1). Now, I'm invoking the macros from another worksheet that I opened in Excel and I'm trying to load the userform that I created:
Sub ShowMyForm()
UserForm1.Show
End Sub
but everytime I try, I get the same error:
Run-time error '424'
Object Required
Can someone help me out here? I'm getting annoied with this thing.
Sub ShowMyForm()
UserForm1.Show
End Sub
Object Required
RE: UserForm1.Show gives an error...
Since u're invoking this from another workbook - which does NOT contain UserForm1 - u get the error msg.
See the VBA help & then try making the proper reference to UserForm1 - and PLEASE don't do yourself the disservice of getting annoyed - the thing'll elude you more...
Good luck!
Place the following code in the module of any workbook (other than one named Book1.xls):
Sub ShowMyForm()
Application.Run ("Book1!ShowForm")
End Sub
Then place the following code into a different workbook in this case called Book1.xls which contains the Form UserForm1:
Sub ShowForm()
UserForm1.Show
End Sub
I hope this solution is adequate for you. Of course if the workbook invoked by the ShowMyForm() macro is not open (in this case Book1.xls) or if it does not contain a macro called ShowForm() you will still get a 424 error.
Inclusion of the following code would do the needful (and avoid the error msg) if the file is not open:
Sub CheckOpen()
BookName = "C:\MyDocuments\ShowFormBook.xls"
For Each Bk In Workbooks
If Bk.FullName = BookName Then Exit Sub
Next
Workbooks.Open FileName:=BookName
End Sub
This sub can be entered into you suggested sub or referred to as:
Sub ShowMyForm()
CheckOpen
End Sub
'ShowFormBook' or 'Book1' in BOTH procedures
Users are supposed to be able to download "sterile" data in a .CSV format (clean of any modules/forms/add-ins) and run the macros I created to generate their charts. What I wanted to do was create a user interface that would allow them to specify the ranges of the data (they won't always want ALL the data in the file), type of chart, etc.
The purpose is to make things more convenient for the users (who will probably have next to no experience with Excel) so they won't have to select the data manually and go through the process of creating the chart. Yeah, I know, lazy bums...
If you could send a sample .CSV and concerned workbook(s), I can try to devise a solution for you.
mala_rs_singh@rediffmail.com
