Galling of 17-4 Plate
I am having a problem with galling on a 17-4 stainless steel plate. The plate moves back and forth and will cycle in each direction once every 15-20 minutes. This plate is sandwiched between two seals(one each side) made from Nitronic 60. Is there a better material combination that I should use? (There is amonia in the atmosphere were this si used so aluminum and bronze are not an option) Is a coating a better route to take?
RE: Galling of 17-4 Plate
Andy
