motor sine wave
motor sine wave
Gentle men and ladies
Iam making a torque tool using either a gerator or gerolator motor (LSHT). What i am not sure on is "as each element comes under presure is there a sine wave build up in the out put torque of the shaft. At present i am driving a a square drive from the shaft and torqueing the bolts at the four sectors of the shaft which means i have to connect and disconnect 4 times.
Any help would be welcome
Regards AUSIRISH25
Regards AUSIRISH25
