Change in my question about Smart fasteners
I just posted a question about smart fasteners. Please ignore that one. The following is the revised version:
First I will state the objective of my exercise:
I needed 2 rows of 5 holes each. The second row is exactly the same as the first row. 5 holes in any given row are not evenly spaced. Final objective is to put fasteners through all the 10 holes.
Now this is how I went about doing this:
I decided that I can't make one hole and then pattern it using Feature Pattern because the distance between the 5 holes in one row is not the same. So I sketched 5 points and then used the hole wizard to create 5 holes. Then, since the second row is exactly the same as the first row, I just used Linear Feature Pattern to pattern the first row and that's how I got my second row of holes.
So far so good. But I ran into problems when I started inserting fasteners. I selected the first original row of holes (that appears as one entity in FeatureManager) and I was able to insert fasteners in all 5 holes at the same time. Then I tried to insert fasteners into the 2nd row (the one that I patterned using the first row) and it won't work!!
Lastly, I tried to select the holes in the 2nd row individually and insert fasteners in them but to my surprise that doesn't work either. I got the message "All hole series have smart fasteners".
Please suggest what I can do.
Thanks to all those who read this.
RE: Change in my question about Smart fasteners
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
A Linear sketch step & repeat can be used to pattern the points used to create the first row of holes, whilst still within the Hole Wizard.
I usually use the hole wizard to make the first hole only, then pattern that hole using either the Sketch driven or Linear pattern driven method.
Ken
Scott Baugh, CSWP
FAQ731-376
