Dumd Question re: Stress/Strain Curve
We did a tensile test on a 4140 specimin used to manufacture a part I want to analyze.  I want to use this information for input to FEA, but have a question:
Q:  Should I convert the stress strain tensile test data from engineering stress/strain to true stress/strain data?  I think the answer is yes but I want to confirm.
Thank You
RE: Dumd Question re: Stress/Strain Curve
I take it that:
1) your analysis is non-linear?
2) your total strains expected in the analysis are greater than 5%?
If both are true, yes you should convert to true stress/strain. Otherwise no need.
Cheers,
-- drej --
Yes, there is some highly localized strain that I am trying get get a better handle on.
Thank You for the response.
