Involute spline
Involute spline
Involute spline
I am wondering you use any diametral pitch (DP) value when designing a shaft and hub involute spline system based on the ANSI B92.1 - 1996 standard.  If so, how do yo calculate the machining tolerance and permissible effective variation when using a DP value that is not defined in the standard.
