Solidworks Custom Properties
Does any one out there have a Program that opens a dialogue box to allow a person to fill in the custom properties easily?
RE: Solidworks Custom Properties
We use "PropertyEditorSpec" mentioned above and it's great for the most part because it is easy to add or delete the properties depending on your company standards.  The only gripe I have with it is that if you have a property linked to a dimension, the dimension does not update.
For example, if you have a property called "length", and it is linked to the length of a tube, you can change the length of the tube, but PropertyEditorSpec does not recognize the change.  Other than that quirk, it is a great macro, especially since other property macros such as "Propagator" are not free, or are not easily modified.
Flores
