What's the application of Motor in the automative?
I'd like to know where the motor is used in the automative or in the future vehicle and which type of motor is often used? DC motor, Brushless DC or AC induction motor? Where can I get an example or futher infomation?
Min
Min
RE: What's the application of Motor in the automative?
fuel pump
engine cooling fan
windscreen wiper
door mirror
seat
blower fan
Go to a junkyard!
Cheers
Greg Locock
Starter
Power windows
Power convertible tops
Adjustable air suspension on SUVs/Trucks
Windshield washer pump
If it weren't for the DC motor, our cars would resemble the Model T!
As an aside, there is no AC past the Alternator rectifier and Brushless DC is too expensive with no added benefit. Most of these motors will die from abuse (excessive cranking with a weak battery or out of tune engine, running the fuel pump dry, etc.) rather than wear out.
Blacksmith
Or not; maybe everybody realizes that until something better than batteries comes along, electricity is never going to beat gasoline on a HP/lbs basis, which is the bottom line for most people.
Ask me? I think we should be putting some more money into small-scale fusion power. But I don't know anything, so nobody would bother asking me in the first place!
Two other motor applications for your list: the electrical side of hybrid car engines, and the regenerative braking equipment in same. Yes, I know those are more like alternators, but the parts and the principles are very similar.
