Showing Dims Automatically in Drawing Mode?
When creating a New Drawing, can one automatically have SW (2004) display/show the dimensions (used to create the part) on the drawing without having to use "Insert Model Items"?
Thanks!
-Art
SW 2004
RE: Showing Dims Automatically in Drawing Mode?
Tools > Options > System options > Drawings
Select first box ... Automatically place dimensions inserted from model.
from (the City of) Barrie, Ontario.
I tried sniffing Coke once, but the ice cubes got stuck in my nose
I do have that option checked? Am I missing something else?
Thanks!
Quote (SWHelp):
When creating dimensions in part sketches, you can specify whether the dimension should be included when inserting model dimensions into drawings.  Right-click the dimension and select Mark for drawing.  You can also specify that dimensions marked for drawings be inserted automatically into new drawing views.  Click Tools, Options, Document Properties, Detailing and select Dimensions marked fordrawings under Auto insert on view creation.
