Volume Calculations for Partially Filled Vessels and Heads
Gentlemen,
I am in a foriegn location and without access to my normal hard copy resources (which in this case would probably be the GPSA manual). I am looking for an internet reference for calculating the volume of partially filled horizontal and vertical vessels with different type heads. This is for start-up and operating solvent inventory calculations. What would be most useful is an excel addin with functions that could take the appropriate arguements and convert level to volume. Otherwise I would like to be pointed to a program, formulas, or a set of data tables.
I previously made a post on this question to which there were two replies, but which the management deleted (or lost) and will not respond as to why. Presumably either the fact I mentioned Excel in the title raised a flag to EngTips, or one of you was abusive in your response (which I doubt). In any event I am involved in serious work and would very much like to get that information again.
sshep
sshep
RE: Volume Calculations for Partially Filled Vessels and Heads
Guidoo!
Thanks for reminding me.
quark, thanks also for the offer to email. I downloaded the good stuff from that site, but I would like what ever you have if it is different. Posting my email here is one reason a post can be deleted, but my email is in my profile if they finish updating that page in the near future.
cheers, sshep
Guidoo was close, but your answer is in Thread794-59784.
There is no telling when the member profiles page will be available and email addresses are frowned on. I can relate to your situation and can help with the answer. Let me know.
Art Montemayor
Spring, TX
