Steam droplet size distribution
Dear All
We have a problem with the quality of pure steam from a pure steam generator. In fact conductivity is elevated.
I have made the calculations for to determine what is the minimum diameter of the drops of water that are settled by the gravity; I have used for the calculation the formula of Souders-Brown.
To this point I have need to know if a statistic method exists for determining what is the distribution of the dimension of the drops in the steam. In this way it is possible to know if the separate drops are the most greater part in comparison to the totality of the water present in the steam.
Help!!
Thank
Help!!
Thank
RE: Steam droplet size distribution
Also, should you not be using high quality water that has very low conductivity in the first place?
