Power Plant cycle
Power Plant cycle
Hi!
Are there any good references to basic principles of oPower plant cycles and heat rate calculations?
S.C.Sekhar
S.C.Sekhar
RE: Power Plant cycle
If you are thinking of a specific area, then that is another question.
I am looking for optimisation of plant cycles and generation of Heat balance diagrams.
S.C.Sekhar
There are several engineering software packages that will perform an iterative heat balance and generate a heat balance diagram for various plant conditions.
If you are only going to perform a single heat balance for a single plant, I suggest that you pay to have a specialist perform the balance...
The "old horse" that has been around a long time is "PEPSE"
try : http://www.pepse.com/ for more info
Anybody else out there have a suggestion ??
MJC
