3-D machines
3-D machines
3-D machines
Seek advise on an NC machine to take 3-D CAD output and produce an object whose visible surface matches that of the CAD object. Desired output max size: h = 45 cm, w = 30 cm (smaller could be OK to begin). Should be capable of thin (i.e. around 1-2 mm). Example: coffee cup made from wood
As an EE I am untutored here. How do I specify such a thing.
wzkb
<They are just Jealous
that the Voices
don't talk to Them>
RE: 3-D machines
As an alternative to milling from a solid block of material, there are technologies for "printing" a 3D part.  Do a web search on the terms STEREOLITHOGRAPHY or SELECTIVE LASER SINTERING.  These technologies can produce a 3D part of various plastic resins, or even solid metal if laser sintering is used.  There is a magazine devoted to these types of technologies called Time Compression Technology.
RE: 3-D machines
Thanks for the tip. I will still need, on occasion, to use real wood.
wzkb
that the Voices
don't talk to Them>
