save, close and exit many autocad session with vba code
Presently I’m searching a way to save, close and exit many autocad sessions in VBA. I have to look at the SDI and MDI mode.
I’m sure you will know someone who could help me?
Steve
Steve
RE: save, close and exit many autocad session with vba code
CODE
Dim ACad As Object
SessionIsOpen = True
On Error Resume Next
Do While SessionIsOpen
Set ACad = GetObject(, "AutoCad.Application")
If Err.Number <> 0 Then
' AutoCad is not running
SessionIsOpen = False
Else
'AutoCad is running
ACad.Quit
End If
Loop
Err.Clear
On Error GoTo 0
End Sub
To save the files that are open in each AutoCAD session insert the following code before the line:
ACad.Quit
CODE
For Each Doc In ACad.Documents
Doc.Close SaveChanges:=True
Next
ACad.Quit
DARE TO IMAGINE
mala_rs_singh@rediffmail.com
