Vis Mockup and Reference sets
  My company is attempting to use Vis Mockup V5 to help non Ug users to see our CAD data.  When in Vis Mockup one of the problems we are having is not being able to see the correct reference set. Has anybody else tried this and had success.  We are also using Teamcenter Engineering V8.
RW
RE: Vis Mockup and Reference sets
Hi realwest,
As far as you know you can find refernce-set in 2 "fields", In a single component you can add some geometry to a reference-set. And in an assembly you can add components to a reference-set.
Vis will support reference-set for a component by translating a reference-set you define (one or more). But for an assembly it is more complicated.
