SOARING BIRDS - Barn doors vs high aspect ratio
Does anyone have any thoughts about the different wings used by soaring birds? Eagles and other birds with low aspect ratio wings generally have multiple spread-out feathers at the tip. How do these feathers work? An albatross has a high aspect ratio wing with tapered tip and often flies in ground effect. Is that a clue? Is the low aspect ratio wing better for load carrying?
RE: SOARING BIRDS - Barn doors vs high aspect ratio
Cheers
Greg Locock
Don't forget that an Eagle has to perform a controlled dive, requiring short span (less inertia for fast turns), while the Albatross operates over a smaller speed range. You'd be suprised how much ornithologists can actually tell you about bird "design"!
Another interesting feature is the trailing edge feathers. At high AOA the trailing edge reduces the tendancy for the flow to reverse (ie stall). The practical upshot is that the aerofoil can be designed to operate more efficiencly, but is more forgiving. Birds are actually not very observant of aircraft...
Mart
Wish I took a picture.
