Measuring RPM of a small motor
Hi!~
It's too small to measure RPM with a optical tachometer.
Is there any method to get RPM of a small motor?
Thanks in advance...
RE: Measuring RPM of a small motor
You can get the surface speed of a shaft with a laser velocimeter. Whether it could focus on such a small shaft is an interesting question.
Perhaps you could look at the drive current with a scope, or analyse the nosie it makes?
Cheers
Greg Locock
if it is really small and turning slowly, use a stop watch...
How about a small mark on the shaft and a strobe light?
Bluenoted,
I've got a mechanical rotation counter in my toolbox.  It is made by Starrett.  It comes with several different sized small rubber couplings that you hold against the shaft.  Run it for a fixed amount of time and do the division and you get the speed. You can probably find one at a tool dealer.
Timelord
Your motor is probably fastened onto a drive.Perhaps it would be easier to measure the RPM somewhere on the drive. With a tinny color strip on a rotating part of the drive you can measure rotational frequency and calculate the RPM of the motor.
m777182
You can always put an accelerometer on it or nearby,  and find the rotational frequency.
If it's not clear from that,  unbalance it slightly,  then try again!
If it's a commutated motor, we have two products that measure motor speed from commutation current.  The first product is older technology, model CRSM1, but we have a new, not-yet-announced product that can track motor speed well enough to allow it to do time-domain averaging of vibration caused by the motor's imbalance.... Contact me for more info if your motor is commutated.... eraftery@cdasys.com
I don't know what kind of motor it is.
May be you can try this software, it works 30 days in demo mode.
http://www.esser.u-net.com/rpm.htm
It uses sound card and microphone.
