Taper Ratio
Taper Ratio
Taper Ratio
What would optimum taper ratio? I read somewhere 2:1, does that mean (exp. 14" root, 7" tip)and over what length? Just advice
Thank you
RE: Taper Ratio
You need more information that that to make any reasonable decision.  Disc loading, power loading, RPM, forward velocity, Reynold's Number, Tip Mach speed...........
Steven Fahey, CET
"Simplicate, and add more lightness" - Bill Stout
