Generator design
Generator design
Can anyone help me with a formula? I need to calculate the force required to move the piston of a linear generator from one position to the other. Specs currently are: 9 kW output at 409 V peak (240 vrms), stator comprised of 188 x 2mm E punchings in a circle to form a cylinder 12 cm diameter, dimensions of E's is 5cm x 5cm coil spaces, 1.46 cm steel width. Armature made of 4 NeFeB permanent magnets with total face area of .00553 sq m and rated 1.2 Tesla. Winding 2 coils ea 2152 turns #20 magnet wire connected "4 in hand", e.g. 4 parallel.
So my question is, will my estimated 597 Newtons force on the piston be able to move it off position TDC onto position BDC?
Thanks for any input.
Pechez les vaches.
RE: Generator design
http://ieeexplore.ieee.org/
Mike Cole, mc5w@earthlink.net
mc5w: Agreed, that looks like only way. Was hoping there might be some math to pre-design with first but apparently not.
Pechez les vaches.
