ASME Internal Volume Issue
Does any particular section of the Code reach
machined, high pressure (3000#) housings with low
internal volume of around 100 cubic inches, 1/2" ports?
The typical view is ASME doesn't apply to housings of this
sort, only to larger welded pressure vessels. I've never seen an ASME coded machined metal housing.
RE: ASME Internal Volume Issue
The following notes could apply to your application;
U-1c, 2c - pressure containers on reciprocating parts or are integral components on rotating pumps, compressors, etc..
U-1c, 2i - vessels having an inside diameter, width, height or cross section diagonal of 6" or less, with no limitation on length or pressure.
Of course, the above exemptions only apply if the Jurisdiction (which is the authority that regulates boilers and pressure vessels where the object will be installed) does not have more stringent requirements regulating pressure vessels. You need to check on this to be sure.
