hidden lines in UG NX2
I've recently converted from UG version 17 to UG NX2. When I open a drawing done in the previous version none of my views have hidden lines displayed properly - they're all visible. I've verified/modified the Edit/Style/Hidden Lines options and updated the views to no avail.
I'm a novice UG user to begin with, so I don't know if I'm missing something obvious.
RE: hidden lines in UG NX2
Check to make sure that your Reference Set in the Part Navigator is not set to "REP". If it is, change it to "PART" and it should care of your hidden line problem.
Hope this helps, Jason
