Geologic Contact
Geologic Contact
When I look at a Geologic Map and there are areas marked as Geologic Contact, what am I looking at?
RE: Geologic Contact
a geologic contact is simply a boundary between different geologic formations, hence a surface where some lithological change, more or less transitional, is expected.
The intersections of the boundary surface(s)with the topographic surface are mapped as lines, which trend is a function of the geometric configuration of the intersecting planes.
For more basic concepts you may want to have a look at the following link:
http://dept.kent.edu/geology/ehlab/fundamentals/fu...
