Change 3d to 2d
Change 3d to 2d
I have used the flatten command to no avail. Is there some new trick to setting all my Z's to 0.00 on a mass scale?
RE: Change 3d to 2d
Command: move
Select objects: all
xxx found
Select objects: [enter]
Specify base point or displacement: 0,0,1e99
Specify second point of displacement or <use first point as displacement>: [enter]
Command:
MOVE
Select objects: p
xxx found
Specify base point or displacement: 0,0,-1e99
RE: Change 3d to 2d
or You can use a lisp, if You want...
Lothar
ADT 2004
ACAD 2002
RE: Change 3d to 2d
RE: Change 3d to 2d
ADT 2004
ACAD 2002
RE: Change 3d to 2d
Thanks!
RE: Change 3d to 2d
Does that describe your problem? If so, I'd like a little expansion on the move-all-Z approach posted before mine.
I'm limited in my understanding of the suggestion by my understanding of the move command. If I move all, all coordinate points move as a body, maintaining their relationship to each other. This would seem to suggest that lines with varying Z's would still have varying Z's, just shifted to the new position as a result of the move operation. What am I missing if the intent is to change all coordinates to Z=0 of a particular plane?
If that's the intent, any of the hundreds of lisp routines "routinely" available should be able to solve the problem. I've even used grips (long slow process) when the employer wouldn't allow external routines (whew) ! Painful, but it works.
I'd love a bit of expansion on my question, though.
Anyway, good luck!
C. Fee
RE: Change 3d to 2d
You're right that in theory the move z's to a high value and back shouldn't change the relative endpoint differences. But AutoCAD can't keep track of the high numbers, and the z's all end up at 0.0. This method works with most common object but may not work with solids or nested blocks. You are right to be skeptical, try it on a line of varying z and see what happens!
Carl
