Assigning Component Part Number- Internal
In design phase, do you require requestor to provide manufacturer's name and manufacturer's part number before you assign your internal part number?
RE: Assigning Component Part Number- Internal
BUT, some companies have weird policies.
Go with whatever policy your company uses.
So why not save a block of part numbers for a project?
So maybe parts 199321 through 199600 are requested with no manufacture or manufacture's part number.
Also some companies have just plain weird policies. I know, have worked for some of them.
Internal part numbers can be given prior to any detailed design work or part identification. In some cases, you know need a box that has certain functionality and you can assign a part number based on that functional partition. Once you're in detailed design, all your part number should be based on actual parts or make/buy of some functionality.
TTFN
