Sizing cables for Dc Motor application
Hi i am re-installing a large machine at the moment
the dc mator is 570 amp F.L.C (300vdc)
the problem is this motor had its feed cables replaced
about 6 months ago and they went on fire about a month ago. I am reluctant to use the same cable again ,there are 2 terminals on the motor each terminal has 3 of 70sq cables terminated.(the cables have only about 1mm of insulation) any assistance would be appreciated
RE: Sizing cables for Dc Motor application
If done in this way there should be no particular hazard even for a full ground fault. I've seen those happen as when brush springs come loose and ground the armature circuit and, will it results in a huge flash and usually a damaged drive, the cables are undamaged.
DickDV has offered some good advice. You need to take a closer look at your cable sizing calcs, as the existing arrangement appears to be marginal.
If we learn from our mistakes,
I'm getting a great education!
For the size of motor that you have this would be cheap insurance.
I onetime went to clean a 4 pole motor and discovered that one of the brushes had popped loose causing only 1/2 of the armature to carry current. I put in a work order to the effect that the motor had been in slow cook mode and needed to be replace Real Soon Now. Sure enough, about 1 month later the motor burned up.
