Text Width
Text Width
Text Width
I am working in AutoCad 2004.  My lineweight and text width were messed up when I started out.  I am trying to fix them.  I have got the lineweight corrected but there is one set of text that is really thick.  It has the same attributes as the other text, which is normal.  The thickness is 0" and the width factor is 0.95
Where can I go to fix this?
RE: Text Width
Check the style??
RE: Text Width
Ya the style is one called main.  It is the same style as the rest of the text in the drawing.
RE: Text Width
The only thing I can think of is that it is because the text is at an angle, because as far as I can tell that is the only difference.  But I don't understand why that would be true since I have plotted millions of different texts at angle and have never had this happen before.
