Joined parts problems?
Is anyone having problems with joined parts losing their mates. I am having problems with joined parts with several holes cut in the skin of a part losing the mates with the penetrations that match up with them. I know the models were good several weeks ago, but I open them up and there are numerous mate errors? What gives?
RE: Joined parts problems?
2) If you are using face mates then try using Plane mates instead but don't offset the planes form the faces. That just a bad as using the faces themselves. Instead use the original planes (Front, Top, Right) to create new planes for mating.
3) Instead of using Joined parts save them as a part from an assembly. If you need them joined together as a single body - use the Combine function.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
For all Newbie's - Welcome to the nerd herd!
FAQ731-376
