SENSING Less material on a Crankshaft
Hi there,
   I have an application in which a crankshaft is manufactured, lately defects have been found on several pieces, the defect is less material as is suppose to be (i have some pics if someone need to take a look), I need to sense in some way to ensure that the piece is always manufacture meeting the specs, does anyone knows what type of sensor could I use? as most of you know the crankshaft is a very precise part made of metal so i need to find a proper method for sensing on line.
