High Temperature Butterfly Valves
Does any one have any vendor leads/information for butterfly valves with a system design of 2300F at 5 PSIG and operating at 1600F at 3 PSIG? The existing valve is an Everest water cooled design that has failed, cracks in the wafer sealing area and with leaks in the water cooling system. The exisitng valves are 10" 150lb ANSI flange design.
Thanks for your help
RE: High Temperature Butterfly Valves
- Thread408-101237 (my post of Aug. 27, 2004) for the VANESSA (and other Manufacturers) websites;
- Thread408-103783 for Tyco Valves & Controls websites.
Hope this helps, 'NGL
