Nyloc nut re-use
Nyloc nut re-use
Does anyone know please, if there a limit on the number of times you can re-use a nyloc nut?
RE: Nyloc nut re-use
For the cost of replacing, use once.
Haggis
Cory
Another discussion came up at the time---counterfit nyloc fasteners, indeed, counterfit 'grade 8' fasteners. I got a batch of 5/16th NF nuts that stripped when torqued to over 144 in/lbs. Torque for that application was supposed to be 300 in/lbs.
Rod
Rattler
