Will DC power distribution be back soon?
We all(?) remeber when Edison and Westinghouse tried to introduce DC and AC as their respective standard systems for power distribution more than 100 years ago.
We also know that AC won - for obvious reasons. And we all(?) still think that the best guy won. Don't we?
But, time and technology has changed. We have more and more electronic devices and more and more switched power supplies. We also get more and more variable speed drives and the micros already are mostly electronic and the computers all use internal DC and and...
All these devices use rectifiers to produce the DC link power. And the rectifiers distort mains voltage and load the Neutral unexpectedly much and and and... They also have losses. And the DC link capacitors are bulky and costly.
Local DC distribution - within a block or within a house - would make things a lot easier. No harmonics, no hot Neutrals no bulky capacitors. Integral VSDs would be a natural thing and not a special motor. So, there is a lot going for DC again. And there will probably be a time when we regret that AC did win. DC will simply be the better solution for local distribution.
Of course, there are problems as well, but I think that it is about time that we took the AC/DC thing under some consideration.
Comments? Anyone? Are there DC islands already? Work in progress?
RE: Will DC power distribution be back soon?
If DC was to be reused, even at a neighborhood level, what voltage would you use? 5VDC ? 12VDC? Something greater?
Efficient DC/DC voltage conversion is complex and expensive.
The wire size for a 12VDC system to supply a single home would be quite tremendous. Typical peak loads of ~100A at 120/240VAC is ~24kVA. This would be ~1200A at 12VDC (allowing for flat line vs. sinusoid). Big wire. Big Losses. You do not even get the 'cancellation effect' on the neutral that the typical 3-wire 120/240 split service provides.
How could you possibly supply industrial-type load levels of several MVA?
How do you cheaply smooth the torque on the rotor a 100hp DC motor?
I fully expect that AC distirbution is here to stay, whether you are talking about the (inter)national grids or at the neighborhood level.
To provide voltage changes and galvanic isolation, AC will long be the necessary intermediate in DC distribution. Search on Asea’s “HVDC Light” program, and if given the chance, tour a converter station. [Unfortunately, I understand both ends of the ±500kV 3100MW Pacific DC Intertie are no longer open for walk-in visits.]
The system used two large battery banks with chargers and backup generators to supply a 240 volt ( 475 Volts was also evaluated ) DC system.
Most of the loads were what would have been to replace large UPS banks and motors. The owner was going to use small inverters to supply tools and other special equipment. the DC section of inverters for motors loads and small inverters ( the inverter section of a UPS) for specific tool loads.
A similar plant using AC distribution would have had up to 2 MVA of inverters and a uninterruptable distribution system. Motors loads would have been on an standby bus powered from utility and diesel generators.
This owner was big enough and was a big enough purchaser to get there way. If they speced tools with a DC input and an inverter for AC power in the tool they would have got it. The same went for Cleanroom fans, if they said They wanted AC motor drives with a DC input they would have got them.
It was favorable but that budget went away and at the same time tool makers and the process got smarter. A dozen years ago a "bump" in the power system was a disaster in some semiconductor processes now most tools and processes can live with them.
key points being
Ease and efficeint transformation
AC motors (DC motors cant beat ac motor in cost and ruggedness)
Short circuit limiting capabiliy
Ease of AC power generaton...DC generators are much more complicated and maintenance prone..and afeter all they 'commutate' AC power to DC anyway..
Also I think AC carries more MW per a given size wire...a 3-phase ac circuit would trasfer power more efficeintly than one or more 2-wire DC circuits...I think (I have not done the math on this)
ALL the DC use you mentioned is in controls/singals and processors..the heavy equipment still uses ans will continue AC power.
Not so much in the US and Europe but in developing countries the distances between load centres can mean that AC lines are well beyond their natural loads and expensive line connected compensation is required, making DC more comparable economically.
DC may also be the only available technical solution in some cases if the idea of undergrounding long transmission lines gains more supporters.
That said, HVDC transmission is definitely the best economically and logically to use for transmission which either a) travels further than about 500 km (300 miles) because the same insulators can handle higher average voltages with DC than with AC
or b) uses insulated cables, e.g. underwater (capacitance I think?)
or c) links distribution systems which would like to be able to maintain and islanding capability. E.g. if the US Northeast had used more DC interconnection at points like Niagra or at all state borders the August blackout would almost certainly have been limited to the one utility which screwed up rather than the huge area it struck. The power transfer of a DC->AC tie can be explicitly set and doesn't much care what happens out on the AC circuit.
In general, a logical modern network for North America should have a continental HVDC supergrid and each state it's own AC grid isolated from all neighbours except through DC connections. Agreed there are some issues re multi-point connections to DC transmission but no theoretical reason this wouldn't be do-able and far more simple and reliable than the present AC network which must be tuned like a longwave radio antena to work at all.
Pechez les vaches.
A DC system, say at 42V, being used for computer loads and anything with an electronic power supply (all of which now have their own internal rectifiers) can be very practical and will reduce costs.
There could be a large single-unit recifier supplied directly from the main AC switchboard, utilizing the proper filters to isolate any harmonics at the source. This would remove the harmonic issues for most AC systems, while leaving AC power for motors, incandescent lighting, heating, etc.
Pechez les vaches.
So which is "best" for energy transfer? AC is great if you want to keep the control and switching cheap and simple. DC is great if you want to transfer raw energy large distances. With dc, just don't try to switch it, interrupt it under fault conditions, or otherwise mess with it - it is very unforgiving.
DC traction systems give enough headaches with earthing, electrolysis, etc. Imagine all that in trumps from a power distribution system!
I don't think either will supplant the other - better by far to use the right one for the right application.
Bung
Life is non-linear...
I noticed early on at Carnegie-Mellon University that the homopolar motor/dynamo was the only true direct current rotating machine. All others, including the Van DeGraff generator, are AC machines with synchronous switching power conversion.
One possible DC system would be a 2-wire system suported by a 180 volt or 192 volt lead acid battery. 4x36=180 volts and 4x48=192 volts. You could use forklift truck batteries either way. Would need a multiple pole isolation switch that would break a bank into its 36 volt or 48 volt pieces for maintenance safety.
For 180 or 192 volts you could run 180 volt motors off of it. 120 volt DC relay coils would need a ballast resistor. The Emerson Maxi-Maestro servo amplifier (5,000 watts nominal) can direct connect and with a small sine wave oscillator connected to the velocity input would give you 120 volts AC - would have to be passed through a 7.5 KVA 120 volt primary 120 volt secondary transformer. The maxi-maetro's cut in voltage for the dynamic braking resistor is 240 volts DC and can withstand a DC bus voltage of about 300 volts DC so even fast charging of the battery will not hurt it.
Mike Cole, mc5w@earthlink.net
Pechez les vaches.
+ Big DC power distribution systems never completely went away. All the phone companies switching centers, and I think all the CO's, all use MASSIVE battery installations and HUGE copper conductors to distribute DC power to their equipment. They never did quite trust those generators to start (and they might have had a point -- how does the reliability of your phone service compare to your ISP?).
+ Alluded to above, but I don't think anyone actually said it -- voltage drop at 12 or 24 or 48 volts is a big pain in the neck. If you need to go any distance at all, the Vdrop can be a much bigger problem than the ampacity, requiring even HUGER conductors.
+ Train systems (like the NYC subways) use DC. I'm not sure why, but I think primarily for historic reasons. Lots of big rectifiers in NYC for those trains.
+ DC power over Cat-5 & Cat-6 is becoming more commonplace every day. Maybe that will start to take over as the default residential DC power distribution system, at least partially supplanting the ubiquitous wall wart DC power supplies (how many of those things do you have plugged in around your computer?).
+ A friend of mine is a big solar nut. One of his biggest pet peeves is the big leakage current running through all the wall wart transformers even when the associated utilization equipment is shut off. Pain in the neck for him because if he really wants to max out his solar system he has to unplug stuff whenever he's not using it. Obviously this is true regardless of the source of 120vac, but it's even more critical when your source is (relatively) undersized and the cost per kW is so much higher. Just one more reason to look for something better than a plain-jane wall-wart as a DC source.
+ DC power transmission was mentioned above -- my understanding is that AC-DC-AC converters are often used to interconnect the national power grids (I'm pretty sure that all connections between California & other grids all use AC-DC-AC).
What are the AC- versus DC-system capacities on the US space shuttles and {proposed} International Space Station?
In response to your earlier post "... and if given the chance, tour a converter station. [Unfortunately, I understand both ends of the ±500kV 3100MW Pacific DC Intertie are no longer open for walk-in visits.]"
I was fortunate enough to get to work breifly at the Dalles Oregon converter station for the Pacific Intertie back in 1996. I will never forget the sight of those huge rectifiers and all the rounded dischage tubes with the big spheres on the ends. I was reminded of old silent movies about the future where everything had an Art-Deco look to it. It was one of the most amazing electrical installations I have ever seen. I wish I had taken pictures or even bought postcards that were in the lobby. Everything there is closed up as tight as a drum now with security cameras, armed guards and electic fences.
"Venditori de oleum-vipera non vigere excordis populi"
GOTWW, your 12/24 volt DC system is something that I would have wanted in my house during the blackout. I ran some 12 volt fluorescent drop lights and my shortwave radio off of my car using extension cords. You could also replace your 12 volt bulbs with DC input fluorescent ballasts from Bodine which would also allow you to upgrade to a 24/48 volt system. SquareD's QO circuit breakers up to 70 amps are rated for that voltage. Bodine has 2 types of DC input ballasts, one type for backing up line voltage ballasts off of central office power and NOT continuous duty rated and the other type that is continuous duty rated and intended for recreational vehicles and off grid buildings.
By the way, many of the subways in NYC and Boston use 25 Hertz power. Only some of them use DC.
My starting point was this: Most lamps, computers, kitchen and other houshold machinery use some kind of inverter technology today. Variable speed is known to save energy in ventilation, HVAC and refrigerators and it is almost a necessity in washing machines already.
So there are between twenty and hundred local rectifiers and DC links in a normal family house. Power range is between ten watts (small computers and lamps) up to one or two thousand watts (ventilation).
All these local rectifiers and DC links have costs, volume and losses associated with them. They also produce harmonics, which can not be dealt with cost-effectively in many small units.
By having one rectifier unit at each entry and distributing DC (I am thinking around 325 V in Europe, the voltage you get when rectifying 230 V), the rectifier can be built with good harmonics mitigation, lower total cost and a lot better efficiency than the twenty - hundred local rectifiers used today.
Existing AC devices with switching power supplies can be used directly on the DC distribution (not necessary to replace all equipment), but those with a transformer between mains and rectifier have to go. Heating will probably also need some consideration since the normal switches are built to break AC - they will not be able to break DC reliably. So there will be problems. But there will be some benefits in the long run and every change has its problems - I know, we changed from left side driving to right side driving more than thirty years ago. It wasn't that difficult and we all benefit from it today.
Sorry, that last part was a bit off topic. More comments to this?
a) 325 - 330 V should work cheaply at central rectifier / distribution for most of the world.
b) using fuses for circuit protection should eliminate high cost of DC breakers, let that market develop if it wants. Alternatively put current limiting electronics in front of branch circuit breakers to allow present standard AC units to serve.
c) A single ring running throughout the home should have sufficient capacity for most smaller loads, then dedicated fused circuits feeding central air ventilation motor, laundry machines, ?refrigerators, etc.
d) Can't see any other problems, shouldn't cost much more than present systems given widely accepted standards on plugs and rated amps.
How much efficiency gain do you think we'd see from it as far as eg. present AC/DC wall warts having their transformers connected 24/7? How much of that will be lost in the central rectifying unit?
What are the odds it could be designed from the outset to carry hi-speed communications to every outlet point as well?
What loads are left which still must absolutely have AC branches (aside from legacy stuff)?
Pechez les vaches.
