Modem interfacing using c / c++
I need the information for the modem interfacing using C via serial Port. I want to know how modem dialer can be designed using C which i need for my project-kavediamanoj@rediff.com
RE: Modem interfacing using c / c++
Check on the documentation for your C compiler, this is so common there is usually a sample code fragment for doing this!!
Good luck.
john
http://computing.net/windows95/wwwboard/forum/3601.html
http://www.computing.net/windows95/wwwboard/messages2/11068.html
(with VB)
Etc. for more info
