Radiate & Induction Heating
Hi there!
I wonder what is definition of Radiate and Induction Heating?
What is the difference between these two heating?
Urgent!
Thanks a lot!
Urgent!
Thanks a lot!
RE: Radiate & Induction Heating
Induction heating is heating an object (often a bearing or metallic ring) by passing an electrical current through it. An induction heater is basically just a transformer. The bearing is located such that it is a shorted turn of the transformer secondary. When the primary winding of the transformer is energised, current flows around the bearing, causing it to become hot.
The "Induction" heat is based on heat generation due to Eddy (or Foucault, Jean Bernard Léon, Pronounced As: zhäN bernär laôN fooko , 1819-68, French Physicist) currents caused by higher frequencies.
