Weight of T-111 panels
Trying to quickly find the weight per sq. ft. of T-111 paneling. I lost a chimney during hurricane Jeanne. The chimney is frame construction, 36" x 36" square by 17 feet tall, with the smoke pipe running up the center. Not counting the framing it is all T-111 paneling. The chimney is in fine shape and could possibily be reused, but I am trying to determine the crane size that would be needed to reset (after I have the connections in the house inspected and rebuilt). The crane operator who lifted it off the roof said it was 2000 pounds. I think this an overestimation. Haven't been able to find it online.
Thanks in advance.
Thanks in advance.
RE: Weight of T-111 panels
5/8 inch thick has grooves 3/8 inch wide and 1/4 inch deep, usually located 4 inches on center. The nominal weight is 1.8 pounds per square foot.
3/8 inch thick has "fake" grooves (they are 3/8 inch wide but have no significant depth), usually 4 inches on center. Nominal weight is 1.1 pounds per square foot.
It is that simple
