HELP 420S37 Stainless Steel
Hi I really need some help, im looking for a metal supplier in the uk that can supply 420S37 in 2mm thick sheets. Required Vickers hardness of 460 apporx, rockwell C 45 etc
All my searches have found nothing
If anyone has any info please let me know
Regards Jonathan
RE: HELP 420S37 Stainless Steel
Try sandvik steel. Im not sure what the s37 means in your designation but 420SS is a martensitic hardenable grade. Sandvik produces lots of harden and pretempered steels in coil form.
Also you will definately need to talk to a specialty supplier if sandvik doesnt have your quantity available.
nick
The Sheffield Special Strip division of Outokumpu Stainless (formerly AvestaPolarit, formerly AvestaSheffield) should be able to provide you with 2 mm strip.  Their contact info is as follows:
Outokumpu Stainless Ltd
Contact:
E-mail:
Phone: +44 114 244 3311
Fax: +44 114 244 8280
Address: Shepcote Lane
P.O. Box 161
S9 1TR Sheffield
You can also try Ugitech (formerly Ugine Savoie Imphy).  They make 4 versions of 420 and sell in the UK
Bob
