Actuators with limit switches
Can you get damper actuators with in-built limit switches. What do they look like? I have been given a proposal to use seperate actuators and seperate limit switch to fit on the damper. Which is better?
RE: Actuators with limit switches
Limit switches on the damper will tell you the position of the damper. Limit switchs on the actuator tell you the position of the actuator, if the linkage is damaged or disconnected then you don't know what the damper is really doing.
Friar Tuck of Sherwood
