Keyboard Functions not working
I am using Autocad 2000. The functionality of command line for typed shortcuts has stopped working. I am now using the icons and with text selected the keyboard works fine so its not the keyboard. Any help would be much appreciated.
RE: Keyboard Functions not working
Dear taffcad,
It sounds like your "acad.pgp" file has been deleted or moved from the "Support" folder. Check and replace it.
Also the REININT command may help you.
Farzad
Check to see if any coordinate entry setting has been changed.  This is located in the Windows Standard Bahavior area in the User Preferences tab of the Options dialog box.  Hope this helps - John
