Pipeline - cathodic protection
Will cathodic protection protect both the inside and outside of a mild steel pipeline? If not, can you provide a basic explanation about why not?
RE: Pipeline - cathodic protection
However, for export pipelines, the stuff inside the pipe is usually dewatered etc so there should be less oxygen corrosion inside...for flowlines with highly corrosive reservoir fluids, clad and internally lined pipelines are used.
