problem with weld beads. any ideas
RE: problem with weld beads. any ideas
Does the Horizontal tube go through the vertical tube?  If so SolidWorks might be confused on what surface to creat the weld bead.  I've done some engine exhaust manifolds which had compound bends without any problems.  Just a thought
yes. on goes through the other, but i dont' know how to prevent solidworks from getting confused without splitting the inside tube.
they are weldments. it gives me an error that there is more than one resultant edge after selecting the tubes and it gets confused is there any way around that?
