Mating arrayed components in assembly
First of all, I would like to thank all the people who have taken the time to reply to my posts in the last few days.
I have a thin polygonal disc (with 16 sides). I would insert this disc into an assembly. Then I need to mate another component (I will call it L-shape) on each of the 16 flat faces of the disc. All L-shape components are the same. So I figured that I can insert one L-shape into the assembly, then Component Array it. By doing this, I will get 16 instances but they wont be mated to the 16 faces of the disc. Is there a way so that I need not individually mate all of these 16 L-shapes to the 16 faces of the disc.
RE: Mating arrayed components in assembly
Then in the assembly, insert a circular component pattern of the 1st l-shape part around the polygon part's axis.
