steam usage
steam usage
hey im an electrical engineer trying to calculate steam flow and usage for a retort.
ok i need to know the steam used in retorting canned vegatables.
i know
volume of retort
specific heat capcitiy of vegatables
pressure of steam flow into the retort is 120 psi
i know the team taken to come up and cook the beans
with all of this i just need to calculate the the amount of steam used in the process.
is there any more information i will need
and what are the equations i would need to estimate steam usage. thanks alot. for any help i may get.
i know
volume of retort
RE: steam usage
RE: steam usage
and when i get the steam flow. im not sure if the steam used during production is caluculated like fluid flow where you multiply velocity by pipe cross sectional area.
thanks alot for your help
