How to create a perforated annular sheet
I need to calculate an annular sheet (i.e a ring-shaped sheet) that is perforated. The sheet ID is 22" and OD is 35.5". The hole size is 1/8". The horizontal and vertical spacing between any 2 holes is 3/16". The holes are staggered. How can I go about creating this kind of pattern on an annular sheet?
Thanks for reading.
RE: How to create a perforated annular sheet
Treat it like a rectangle ... Do 1 or 2 linear patterns & delete (skip) the holes not required.
from (the City of) Barrie, Ontario.
I tried sniffing Coke once, but the ice cubes got stuck in my nose
One method that we have used before is to make the pattern on the id by using two or three planes angled in the proper manner and cut-extrude thru to the od.  then array the pattern as needed to match your desired geometry. There may be another way that is a bit better.
Good luck, i will do a little testing and see what develops.
Jay
Or ... make a rectangular perforated sheet first, then cut-extrude the ring.
I am assuming that the holes need to be radial.  I am working on a 3d sketch that should do what you want.  I will get back to you with more info shortly.
Jay
adymech1,
I have a model that may help you out. if you want, my e-mail is jayk@dicarinc.net.  I can send it to you. this may help you understand how I made the features.
Jay
jbknudsen
I'm confused ... angled planes, 3D sketch, radial holes ... are you creating a perforated cylinder?
Unless I am mistaken, I think the original post was asking how to create a perforated flat sheet "donut".
