Perforated Ceiling Air Distribution System
Has anyone used a perforated ceiling air distribution system? Results? Advantages? Problems?
RE: Perforated Ceiling Air Distribution System
Friar Tuck of Sherwood
If so, you can use someone like AAF American Air Filters who I believe do special ceiling systems with lay in filters. The filters lay in a non-setting glue or gel that provides the seal.
the ceiling is also high strength to take the higher ceiling space pressures that you may experience, though I dont think it will be much with such a relatively low volume flow and face velocity.
You will also need to extract air at low level to achieve a more effective room airflow
do you know what clean room classification you are after?
You also need to carefully design your duct work to avoid short circuiting of the air. I will prefer static regain method in this case.
