Circles look as Polygons...
Very often as I extrude circle, and than render, somehow thay look "jagged" thay loose roundness, is there some settings to acheive finer look of circles?
RE: Circles look as Polygons...
Tools\Options\Document Properties\Image Quality
This will however slow you down the smoother you make it.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
Thanx SBaugh,
I know, it must make me slower. but sumetimes, you gon unexpected results, which must be fixed up...
