Listing the Node Coordinates along with Solutions in the same file
I was wondering if it's possible to list both Nodes coordinates and their solutions in the same file. I need this because the solution is provided only in a few selected nodes, and the listing of their coordinates lists all nodes selected. So I can't plot any results as a function of X or Y coordinates.Here is an example:
/PREP7
/TITLE,Bump
ET,1,PLANE121,,,1
V1=200
H1=15   !(V1/H1)*3=EFSUM_MAXIMO
V0=0
R1=0.5
L1=10
MP,PERX,1,1
k,1,0,R1,0
k,2,0,0,0
k,3,R1,0,0
LARC,1,3,2,R1
k,5,L1,0,0
k,6,L1,H1,0
k,7,0,H1,0
l,3,5
l,5,6
l,6,7
l,7,1
LESIZE,1,,,39
al,all
SMRTSIZE,1
aatt,1
AMESH,1
FLST,2,2,4,ORDE,2
FITEM,2,1
FITEM,2,-2
/GO
DL,P51X, ,VOLT,V0
FLST,2,1,4,ORDE,1
FITEM,2,4
/GO
DL,P51X, ,VOLT,V1
FINISH
/SOLUTION
SOLVE
FINISH
/POST1
ETABLE,SENE,SENE
ETABLE,EFX,EF,X
ETABLE,EFY,EF,Y
/NUMBER,1
PLNSOL,VOLT
/SHOW,WIN32C
/CLABEL,1,0
/CONTOUR,1,100,AUTO,,
/DEVICE,VECTOR,0
/CTYPE,0
/FOC,1,,-0.3,,1
/REP,FAST
/EFACE,1
PLNSOL,EF,SUM,0,
LSEL,S, , ,       1
lplot
NSLL,S,1
nplot
/AUTO,1
/REP,FAST
PRNSOL,EF,COMP
NLIST,ALL, , , ,NODE,NODE,NODE
Thanks in advance!
RE: Listing the Node Coordinates along with Solutions in the same file
Hi!
You can create your own file.
For your example copy the following lines in to the ANSYS input line!
LSEL,S,,,1
NSLL,S,1
*create,hhhh,mac
  !maximum node number
  *get,n_max,node,,num,maxd
  !node count
  *get,n_num,node,,count
  !temporary array
  list_tmp=
  *dim,list_tmp,array,n_max,10
  !status of selection (masking vector)
  *vget,list_tmp(1,1),node,,nsel
  !filling array with node numbers
  *vfill,list_tmp(1,2),ramp,1,1
  !# geting locations #
  !node coordinates (X , Y , Z)
  !X
  *vmask,list_tmp(1,1)
  *vget,list_tmp(1,3),node,,loc,x
  !Y
  *vget,list_tmp(1,4),node,,loc,y
  !Z
  *vget,list_tmp(1,5),node,,loc,z
  !# geting results #
  !EFX
  *vget,list_tmp(1,6),node,,ef,x
  !EFY
  *vget,list_tmp(1,7),node,,ef,y
  !EFZ
  *vget,list_tmp(1,8),node,,ef,z
  !EFSUM
  *vget,list_tmp(1,9),node,,ef,sum
  !# reduce results #
  !EFSUM <> 0?
  *voper,list_tmp(1,10),list_tmp(1,9),gt,0
  !count
  *vscfun,sum_count,sum,list_tmp(1,10)
  !Array for reduced nodes (nodes with EFSUM <>0)
  list_red=
  *dim,list_red,array,sum_count,8
  !reducing array
  *do,i_,2,9
    *vmask,list_tmp(1,10)
    *vfun,list_red(1,i_-1),comp,list_tmp(1,i_)
  *enddo
  !# writing array to text file #
  *mwrit,list_red(1,1),list_file,txt,,jik,8,sum_count
  (1F6.0,7F10.5)
  !# writing min / max values #
  !index locations of min / max values
  *vscfu,m1,lmin,list_red(1,5)
  *vscfu,m2,lmin,list_red(1,6)
  *vscfu,m3,lmin,list_red(1,7)
  *vscfu,m4,lmin,list_red(1,8)
  *vscfu,n1,lmax,list_red(1,5)
  *vscfu,n2,lmax,list_red(1,6)
  *vscfu,n3,lmax,list_red(1,7)
  *vscfu,n4,lmax,list_red(1,8)
  !writing min / max values append to file
  /nopr
  /out,list_file,txt,,append
  /gopr
  /com,
  /com,
  /com,
  /com,MINIMUM VALUES
  /com,NODE :%list_red(m1,1)%;%list_red(m2,1)%;%list_red(m3,1)%;%list_red(m4,1)%
  /com,VALUE:%list_red(m1,5)%;%list_red(m2,6)%;%list_red(m3,7)%;%list_red(m4,8)%
  /com,
  /com,
  /com,MAXIMUM VALUES
  /com,NODE :%list_red(n1,1)%;%list_red(n2,1)%;%list_red(n3,1)%;%list_red(n4,1)%
  /com,VALUE:%list_red(n1,5)%;%list_red(n2,6)%;%list_red(n3,7)%;%list_red(n4,8)%
  /out
*end
hhhh
/del,hhhh,mac
*list,list_file,txt
have a nice day ..... Stefan.
Also you can sort the matrix with the *MOPER command with SORT option!
Thank you alot! It really worked for me and now I can continue with my work. Thanks again!
Best Regards!
