HoneyComb Panel Closeouts
I was just wondering if anyone could tell me how much load the closeouts in a honeycomb panel assembly would carry. Would considering the panel (i.e. skin/core/skin) to carry any bending load adequate or would the closeouts also have to be included.
RE: HoneyComb Panel Closeouts
www.carbonfibersolutions.com
I'm assuming your talking of sections going from monolitihic to sandwich panels, and the closeout being the portion between?
In the closeout portion, it is more important to show that the core shear value is adequate to allow distribution to flow between inner and outer skins, to the monolithic part.
The entire periphery of the honeycomb panel receives Edge fill. This process is to prevent moisture ingression only. Currently the only post production edge filling techniques I know of require many man hours with spatula and high consumption of edge fill material (pot life).
I am looking for a process and tool system that would cut the core approximately 0.25 inch deep and pressure inject the syntactic film.
Typically, I would purchase the panels edge filled by the manufacturer, however, this project requires specific shape cut of the panel prior to syntactic edge sealing.
