Extrude along 3D Polyline
While extruding an object along a 3d spiral, the object rotates around the spiral. In example, if I draw a spiral and try to extrude a trapezoid through it, than after a few turns on the spiral the trapezoid stays upside down.
Is there a way to keep the object parallel to the coordinate system?
RE: Extrude along 3D Polyline
All extrude figure will twist on the 3d spiral.
IT is a ACAD limitation, as far I know
Pardal
http://www.eng-tips.com/viewthread.cfm?qid=101312
Pardal
