geom cons in sketch
geom cons in sketch
geom cons in sketch
In sketch, i can not see center of arcs or circles to add coincindent constraint.
why and where?
RE: geom cons in sketch
While the sketch is active.  Go to Preferences -> Sketch... and check the "Display DOF Arrows" box (middle of Sketcher Preferences Dialog).  Each sketch retains it own preferences.
ugDeveloper
You don't need to see the center of the circles to apply coincidence, simply select both circles & choose the constraint you wish to apply.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Well, an example where you need to pick the circle center is, when applying coincident constraint between a line end point and a circle center.
Erland R. Nielsen
Denmark
Correct, Erland, I was thinking concentric.  My mistake.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
