Bernoulli's equation clarification
Hello Guys,
Regarding Bernoulli's equation, will a flow with high static pressure and low velocity have the same impact on a blockage in the flow path as a flow with low static pressure and high velocity?
Thank you
Thank you
RE: Bernoulli's equation clarification
the simple answer is no...
