Removing or Cavity
Removing or Cavity
Removing or Cavity
Is there a way you can remove/cavity one model from another using Inventor 9. Much the same way as Solidworks has a cavity tool.?
RE: Removing or Cavity
Look into derived parts...My site has tutorials
Sean Dotson, PE
www.mCADForums.com
CAD Professionals & Consultants Discussion
Thanks Sean I have manage to use derived parts with no problem, and I have derived a surface to create a mould, I thought there would be an easier way, like the cavity command in solidworks,
I can't see anywhere, where to subtract a component from another, or join even. It does mention this in the help, but has no tutorials.
Unfortunately your website says "coming soon"?
Ian Corless
Thanks Sean got that. works too. Not ideal but its there.
cheers
IanC2
